Signal Analysis Question?
Need assistance in determining if a LabView function or vi exists that can take data from the Peak Detect function and determine the 1/2 power points or sidebands.  This seems like a standard processing thing and is common in vibration data analysis. Any alternate approach would also be appreciated.
(3,309 Views)
With the Sound and Vibration Toolkit we have a Power in Band VI that you can use to determine the power in the sidebands. Additionally, there is a good document online that uses very little programming and shows how to do a half power measurement:
http://www.engr.iupui.edu/me/courses/me340lab/labexp11.pdf
Hope this helps!
Brian Spears
(3,281 Views)
Brian,
Thanks. Unfortunately we do do have the sound and vibration toolkit and I'm not sure that it does the job. What is happening here is that I use the peak detection vi to extract peaks from a range of amplitude vs frequency data. The canned vi is performing a 3 pt poly fit to determine peaks but does not necessisarily return the actual peak . Instead the peak is determined from the curve. Since I do not have the curve coefficients I cannot work torward the .707 peaks which represent the 1/2 power points. If I could do that then calculation of Q would be straightforward. I am trying to avoid reinventing what somewhat else may have already done. Isn't that what LabView is all about?
Fran
(3,262 Views)
Hey Fran -
Here's a VI which will use the half power measurement technique to compute teh damping factor of a signal.  This VI is built with analysis from the Sound and Vibration Toolkit.
-Jack
(3,225 Views)
