Siglent SDG2000X Series Function Generator Using LabView
This is for anyone who has experience controlling a Siglent SDG2000X Series function generator using LabView.  I am trying to use the "Create Arbitrary Waveform" block provided by the drivers.  The input that it takes in order to create your own arbitrary waveform is a 1D array of values.  However, for whatever values I input into the block, I am getting the same square wave output with an offset every time.  I even tried to put my values in the example that they provided for creating arbitrary waveforms and it does the same.  Also, the example as they have it doesn't work how it is suppose to but it does output something other than a square wave.  Does anybody have any idea what the solution may be or if there is one?  I can include example they provided to create the arbitrary waveform.
Thank You
(3,042 Views)
Hello lucasphee,
1. Can you reply with screen shots of the behavior you are seeing? Specifically screen shots of what you see for different values you input.
2. What driver are you using in order to work with the device in LabVIEW?
Kendal C.
Technical Support Engineer
(3,007 Views)
I switched the equipment I was using to accomplish what I needed to but thank you for the reply.
(2,986 Views)
