Show which case in case structure is running
I want to know which case is run in "Case Structure".
I tried to send data into each case, but in case that not running, I want know it.
(1,965 Views)
Hi Waruntron,
THINK DATAFLOW!
When you want to know which case is called then you should place that indicator before the case structure!
(1,936 Views)
You have three cases on a loop that only iterates twice.
With a bit of coding, you can keep statistics on how many time each case executes, but I think your problems are a bit simpler.
Obviously, your example got simplified so much that it no longer makes much sense.
Can you take a step back and explain what you are trying to do? Where does that string array come from? Why are your indicators buried deep inside case structures?
I have the feeling that better written, you might not even need a case structure. What problem are you trying to solve?
(1,929 Views)
Thanks, it's very helpful to me.
(1,923 Views)
What is?
(1,892 Views)
