Show/Hide indicator or control pragmatically
Hello all,
Phew back to labview after a long ternious work with electronics and mathematica.
Question : How can I change the appearance of any indicator or control programitically. I have a button on front panel which when clicked should display the indicator or not.
How can I do that ?
Thanks Smiley Happy
Abhilash S Nair
Research Assistant @ Photonic Devices and Systems lab
[ LabView professional Development System - Version 11.0 - 32-bit ]
LabView Gear:
1. NI PXI-7951R & NI 5761
2. The Imaging Source USB 3.0 monochrome camera with trigger : DMK 23UM021
OPERATING SYSTEM - [ MS windows 7 Home Premium 64-bit SP-1 ]
CPU - [Intel Core i7-2600 CPU @ 3.40Ghz ]
MEMORY - [ 16.0 GB RAM ]
GPU - [ NVIDIA GeForce GT 530 ]
Message 1 of 9
(11,851 Views)
Create a property node and write a true or false to the 'visible" property whenever the visibility should change.
Message 2 of 9
(11,849 Views)
Thank you. It has been very helpful.
Abhilash S Nair
LabView Gear:
Message 3 of 9
(11,839 Views)
Why am I not able to reproduce the same effect with data[64] array ?? I use the same method of provoking visible property node via a boolean button ; in this case a slide button called "show readings" ... Why is this happening ?
Abhilash S Nair
LabView Gear:
Message 4 of 9
(11,834 Views)
Attach your VI.  There is no reason I can see why it wouldn't work.  It must be related to something we can't see in your small piece of screenshot.
Message 5 of 9
(11,819 Views)
Please find the attached VI
Abhilash S Nair
LabView Gear:
Message 6 of 9
(11,808 Views)
Accepted by topic author abikutn
Since you placed the property node inside the DSP case, it will only work if that case executes. Does it?
Why are you using a local variable instead of the terminal directly?
Is this a subVI? How are you actually running this? If this is a toplevel VI, you should place a parallel loop with an event structure to toggle the visibility independet of the state of the main loop.
Message 7 of 9
(11,800 Views)
I had to delete the broken code since I don't have your FPGA nodes.  Then I was able to run your VI just fine.
How are you running your VI?  You don't have any while loop.  Are your running it as a subVI in another VI which has a loop?  You don't have any terminals attached to your connector panel.
If you haven't set your selector to DSP before running your VI, then your code that sets the visibility of the control won't run.
Message 8 of 9
(11,798 Views)
Yes thats correct. It depends purely on case.
Thank you. @
Abhilash S Nair
LabView Gear:
Message 9 of 9
(11,757 Views)
