Show 2 characteristics in 1 Graph
Hallo all,
I have some question about showing 2 characteristcs ( 1 array as X axis and 2 arrays as Y1 axis and Y2 axis) in 1 Graph.
To make it clear , i attachted my program.
Any answer will be helpful
Thanks in advance
Maxwell
(2,768 Views)
If you turn on the "Show context help" and then put your mouse over the XY graph on the diagram, it shows that if you create multiple XY clusters (as in your case 1) they can be fed into a "build array" and then fed to the XY as the case I've attached.
P.M.
Putnam
Certified LabVIEW Developer
Senior Test Engineer North Shore Technology, Inc.
Currently using LV 2012-LabVIEW 2018, RT8.5
LabVIEW Champion
(2,760 Views)
Hi, I have edited your vi, and reposted it. You need to bundle each x and y array together, then build them as an array in order to have the multiple plots appear. Hope this helps!
Geoff
(2,756 Views)
We're like LabVIEW sharks, swimming around looking for questions to be answered, who can be the first to swoop in and type/wire faster!
P.M.
Putnam
LabVIEW Champion
(2,754 Views)
Haha, yeah I know! Although I seem to be the slower of the two! I'd be hungry!
(2,751 Views)
