Shortcuts with different keyboards
Hi to all. I wonder to know how to modify some key shortcuts that are not in the menu list.
I.E. I'm making mods on a LV2017 version VI and I can't upgrade it (it's not mine). I have to change the Increase Font Size from Ctrl+= because in the italian keyboard the "=" is not direct but is Shift+0. So, if I press Ctrl+Shift+0 it's not working.
I'd like to know if there is a table I can change or the Labview can use the local keyboard codes, instead the US ones.
With the new LV2024, they changed resizing to Ctrl+< and Ctrl+>, and even if my keyboard have < and > on the same key, in this case it works even with the Shift.
(605 Views)
Use Ctrl-+
The menu text is wrong.
Paolo
(562 Views)
Right, Ctrl+"+" is fine thanks
(519 Views)
