This widget could not be displayed.
Shortcuts for change in read/write (control/indicator)
I try to find a shortcut for change to read/write a local variable ?
Sylvain Jourdan
(Labview 2012 - English)
(3,192 Views)
Hi Sylvain,
there's no shortcut.
You may suggest an idea in the LabVIEW-IdeaExchange, but I doubt you will be successful as nearly all keys are used for shurtcuts already. Other option would be a QuickDrop plugin...
(3,183 Views)
Thanks for you quick answer, I'll suggest this idea in the LabVIEW-IdeaExchange.
An other idea, do you know if we can add a property to the shorcut menu by modifying a configuration file... ?
Sylvain
(3,175 Views)
