01-08-2015 11:02 AM
Hello all :
I'm very new to LabView and infact, I just downloaded the software. I apologize for asking a basic question, as this is a high time in my experiment to start learning Labview from scratch. Let me explain you my situation and queston :
I'm researching on mice brain . At this stage, i need to stimulate a neuron by shining an LED light on it for every 5 seconds. I was told that, shining light for every 5 seconds can be automated if we use LabView. So can you pls suggest how to proceed with this.
I know i must download the drivers of my LED light source in order to connect it with LabView. Once I'm done with that, how should I proceed? Is there any previously writen code for that?
01-08-2015 11:07 AM
01-08-2015 12:44 PM
Will you find a ready made mouse brain stimulation program??? Doubt it. But the good news is it should be a very simple app to program and get your feet wet with LabVIEW. There may or may not be drivers available for your light source. What is the make and model? What kind of timing accuracy do you require?
01-08-2015 02:41 PM
What are the specifics of the LED driver you are using? It is hard to give advice on this without that information.
