09-26-2008 04:17 AM
I have managed to transfer data from 'Read Measurement file' and am able to graph it.
However, I was wondering how do I shift waveform on the x axis or y axis. I know one way is to change data from the LVM file but is there any VI that I can use to do the shifting?
Ridwan
PS: How do I rate an answer?
Solved! Go to Solution.
09-26-2008 07:46 AM
Use Offset of the Waveform to shift over X-Axis
Add a double constant to your Waveform to shift it over Y-Axis
09-26-2008 09:04 AM
Hi Eugen,
I've tried adding both the offset as well adding a constant to the waveform but to no avail. It only shifts up and down. I'd like to shift it left and right. Was wondering how to do it. Attached is the VI i'm working on. i seem to be having trouble sending a test lvm file.
Anyway, i'm using labview version 7.1.
Ridwan
09-26-2008 09:22 AM - edited 09-26-2008 09:23 AM
What I think is not the value offset, but the time offset - t0
09-27-2008 06:51 AM
Hey Eugen,
Ha ha.. I'm sorry for getting it wrong but i'll give it a try.
Thanks a lot buddy.
Anyway, how do I rate answers?
Best Regards
Ridwan
09-27-2008 07:05 AM
