Sharing NSVs in a local network via NI-PSP
Hello community,
I have an issue with sharing NSVs between different PCs in my local network. Currently I have one master PC that is sharing NSVs via the SVE and I have several other PCs that can read those NSVs. I can see that via the distributed systems manager. I needed to transfer the project of the master PC to a new PC, but when I deploy the NSV library on the new PC none of the other PCs can read the data, e.g. they are not visible in the distributed systems manager. Do I need to do some changes to the new Master PC for it to connect to the SVE? My current software setup is appended and identical to the old software setup.
Thanks in advance.
Best regards
Justin
Message 1 of 1
(799 Views)
