Shared variables not updating in exe
Hi Gary,
During to create the EXE be careful to mark shared variable deployment check box.
Personally I suggest you to create your shared variable coding programmatically. So no need for external inputs. This will avoid all unexpected errors.
Create your variable library, configure data, save it and deploy it. I found this is the best way to deal with shared Variable.
Thanks and Regards
Himanshu Goyal | LabVIEW Engineer- Power System Automation
Values that steer us ahead: Passion | Innovation | Ambition | Diligence | Teamwork
It Only gets BETTER!!!
Message 11 of 12
(792 Views)
Hi all
I have the same issue. Is bound to be a silly overlook.
I'll impleemnt the suggestions and come back.
Gary, did you find a suitabel solution?
Mugur.
Message 12 of 12
(756 Views)
