Shared variable
Hi to all.
I collect data from different computers. The data forms one array. How can I set the specific elements of the array on different computers? I did it on a local machine use notifier array. But via network that will not work. If I'm going to use shared variable then I need read all array and write it on each computer. Or I need to create many shared variables and write to them. But in this case they have a quantity limit.
Message 1 of 14
(5,743 Views)
HI Forest,
You cannot…
Yes.
Why? Which limit? Which quantity?
Message 2 of 14
(5,728 Views)
You might also consider a different architecture. For instance, you could create your own "network notifier" using, for instance, UDP. If you need lossless communication then Network Streams might be an option.
Message 3 of 14
(5,713 Views)
I mean if quantity of parameters will increase I need add them and recompile the app.
Message 4 of 14
(5,703 Views)
Hi Forest,
you could also change the datatype of your shared variables to something like [number of channel, value of channel] (or even better [name of channel, value of channel].
Then combine this with a key-value-pair based table to hold the values of all channels…
Message 5 of 14
(5,694 Views)
@GerdW wrote:
Hi Forest,
...combine this with a key-value-pair based table…
The problem is each computer must read all the table(or array), change a few parameters values and then write all table. And it's wrong. I need something, which will be in server and have a variable size.
Like if I could programmatically create shared variables.
Message 6 of 14
(5,677 Views)
Hi Forest,
have your clients read the whole table, but send back only the changed parameters/entries!
Message 7 of 14
(5,671 Views)
Would you show, how it possible? I don't imagine how I do this with shared variables.
Message 8 of 14
(5,635 Views)
Hi Forest,
Have your server provide two variables:
  1. the whole table so your client can read them
  2. a cluster of (atleast) "index, new value" so the clients can send commands to update single values
Now a client can read the table, do its changes and send the information changes to the server…
Message 9 of 14
(5,629 Views)
Do you mean like that?
But if the clients will in asynchronous write. They will not interfere each other?
Message 10 of 14
(5,618 Views)
