Shared variable on network problem!!!
I worked for two days trying to use the shared variable simple application in my network.
I am using LV 8.6.1 and only one library. Using this setup in my computer code and executable worked well, but when I am sharing the library variable with one network laptop the client is not able to update the variable or better saying it reads first run (not from the server, but I do not know where from), updating even the timestamp, then times out.
Please help me with some suggestion. I opened and run all type of applications that were attached from this forum discussions but they do not work.
I read all type of articles from NI site, I like the concept of shared variable but I can not use it.
Please find attached the example from which an exe can be created.
Thank you,
Virginia
(2,834 Views)
Hi Virginia,
I'm having some trouble understanding your setup.  Which computer is the client and which the server?  Are there any errors associated with this?  What is this VI trying to accomplish?  Have you tried stripping it down to a simpler program and seeing if you can make that work?
Stephen Meserve
(2,807 Views)
