Shared variable error -66208
I’ve got a problem with my LabViev project.
LV can’t save a value into a cRIO output.
In the project I use a cRIO-9039 with a NI9264 - 16-channel +/-10V analog output module.
I want to write into the AO7 voltage value, but it returns me an error -66208 (visible on the screenshot)
When I try to force the AO7 value through NI Distributed Manager it works properly.
Restart of the cRIO or the whole system didn’t help.
Has anyone experienced a similar problem? What should I do?
(2,470 Views)
I think your shared variable engine in services was stopped .
you can restart the service then try again if it occurs again.
bhovhann
(2,393 Views)
