07-23-2018 04:46 AM
Hello together,
according to the white paper http://www.ni.com/white-paper/4679/en/ on shared variables, the variables are made available to the network when the 10-ms timer of the LogosTX is fired. However, in the labview project, I can set the "Network Publishing Period" manually. How are they related to each other? Is the network publishing period restricted to the 10-ms of the shared variable engine?
Best wishes
Lysandros
Solved! Go to Solution.
08-01-2018 07:35 AM - edited 08-01-2018 07:35 AM
Hi Lysandros89,
I checked it with LabVIEW 2017 and it coerces the Network Publishing Period to 10ms when I input value lower than that.
Do you need to update shared variables in shorter period? Can you explain how you want to use this information?
Best Regards,
Maciej
08-03-2018 12:41 AM
Hi and thanks for your respose.
I was wondering how the publishing perion can be set by two different methods, but now it makes sense.
The data are transfered through the network only for monitoring/parameter adjustment, so it is not time critical.
