Shared Variables between Windows and Linux
Hi everyone,
I am having trouble in a project. I have a Windows environnement supposed to send parameters to a Linux one using LabVIEW. Here is my question : Is it possible to use shared variables with a Windows host and a Linux client ?
Thanks for your answers.
(3,254 Views)
Yes, you can do that if the linux client is also running labview based application.
(3,224 Views)
Hi Hritzgujarati ! Thank you for your answer !
Yes, sur, I did not precise it, but my linux application is based on labview.
So I did a VI using Datasocket for the linux part (as it is the only way to used shared variables in linux). It seems to work (there is no error returned), but I don't get the result of my variable... Do you know where I have a mistake ?
I join my linux part code.
Thanks again !
(3,208 Views)
