Shared Variable triggering
Hello everyone, I have two projects (one is in 64bit LV, the other is in 32bit LV) that I run side-by-side on the same machine. The 64bit project controls a camera, and the 32bit project calls some code to do processing. I would like to send a trigger to make the 64bit program wait until some of the raw data buffers are processed before sending more data to the 32bit project. Unfortuantely cannot recomplie the code for 64bit processing.
Are there any good examplse of doing this? I was thinking of using some sort of shared variable setup, but I really dont like shared variables.
(3,462 Views)
Well, I can't help you in everything.
But I think you should at least consider using some sort shared variables setup. Maybe they fit to your situation. BTW, if you post your code it might help.
Best regards!
Mondoni
(3,457 Views)
I am not against using shared variables, I am just looking for a solution in which they can be used as triggers for parts of code in other vi's.
(3,428 Views)
Accepted by topic author dbrittain
You can send commands through tcp/ip to the different processes, e.g.
Network shared variable is probably slightly easier, but not alot.
/Y
Qestit Systems
Certified-LabVIEW-Developer
(3,420 Views)
I figured it out, I ended up using tcp/ip and some network shared variables for less imporntant stuff.
(3,386 Views)
