Shared Variable Properties
Hello
Using shared variables with the waveform double type please explain the
significance of Network properties which shows options:
No. of Arrays
No. of Waveforms,
Points per Waveform.
Also elaborate for RT FIFO property in the shared variable. It has different
options like
single element, multi element etc. in the drop-down menu.
In which case it is required to enable & use this.
Thank you.
Tej Trivedi.
(5,276 Views)
Hi Tej,
Here there are few useful links which can help you to understand about shared variables in a better way.
https://www.ni.com/en/support/documentation/supplemental/06/using-the-labview-shared-variable.html
http://www.ni.com/white-paper/5484/en/
hope this helps.
Regads,
M.Kishan
(5,226 Views)
Thank You, Kishan.M
I had gone through these links.
What I want to know is the significance of that 3 items for Waveform double type shared variables.
Thanks & Regards.
(5,214 Views)
How much data you can buffer on the network.
Click the help button that screen.
(5,197 Views)
The help document that RavensFan is talking about is this
https://www.ni.com/docs/en-US/bundle/labview-api-ref/page/resource/dialog/variable/featurepacks/netw...
RT FIFOs are explained in a bit more detail at the bottom of this help document but you are mostly only going to use this when reading or writing to a variable inside of a timed loop in a real time VI. The RT FIFO functions should also be used in place of queues if you are communicating to or from a timed loop on a real time device. Not using this feature can lead to priority inversion because of shared resources between the reader and writer.
https://www.ni.com/docs/en-US/bundle/labview-real-time-module/page/sharing-data-using-shared-variabl...
(5,180 Views)
I have 32 wavefrom arrays to write using 1 shared variable. In this case when I kept no. of arrays 1 or more than 32 it didnt make any difference in the output when I read the same variable. Then what is the significance ???
(5,134 Views)
