Shared Variable Communication on PDA
I stumbled across something when using LV8.5 networked shared variables to communicate between a cFP2120 running RT5.0.1 and a PDA running Windows Mobile 5.
The problem seems to occur when creating shared variables from custom controls that contain enums. As soon a custom control contains an enum, the shared variable based on teh control will not contain the proper info in any of its fields. This seems to disappear when I convert the enum into a 32bit signed integer, or remove the enum alltogether.
Has anybody seen this before?
Btw, using networked shared variables from custom controls with enums works great in Windows eXP / XP.
Volker
(3,547 Views)
Hi Volker,
I am going to do some tests and look into this.  Thank you for reporting it.
Best Regards,
Bryan H.
(3,526 Views)
Hi Volker,
I tested this with LabVIEW 8.6.1 with Windows CE and did not have any problems.  Windows Mobile is based on Windows CE.
Best Regards,
Bryan H.
(3,511 Views)
Are there any major differences between the mobile module for LV 8.5 and 8.6.1 and how they handle shared variables?
Try dropping a cluster control into a vi front panel and add a numeric control and enum to the cluster. Then make the cluster a type def and use this as basis for the networked shared variable.
In any case; my workaround is to change the shared variable type to a string and flatten all the info to a string using the type def. Unflattening the string on the PDA side seems to yield all the correct values.
Volker
(3,506 Views)
Hi Volker,
I did it with the enum in a cluster and had problems.  When I did it the first time I had a numeric contol and an enum control.  I wrote both to shared variables.  They both updated fine.
This time I added another shared variable that had an enum and a numeric control.  I wrote the same values to the cluster variable as the other two variables.  The values in the cluster did not update, while the other ones did.
I am going to do some more testing on this tomorrow.
Thanks again for reporting this.
Bryan H.
(3,489 Views)
