Setup multichannel FPGA Butterworth Filter with configurations in RT host, cRio
Hi! I've done a little searching for answers here but am still confused, so I figured it was time to write my own question.
I have an engine control application with an entire (32ch) 9205 module's worth of medium speed analog inputs. I'd like to add a lowpass filter for each channel, and I'd like to be able to adjust the cutoff frequency from the RT during runtime (or ultimately with a field technician host utility).
I’m having a problem with the RT implementation of the Butterworth Coefficients vi. I made the assumption that I could set up the RT filter configuration vi in a for loop to generate configurations for each channel. I did have this code run successfully once (I think), but with a large RT processor penalty. After attempting to change the cutoff frequency from the RT, labview lost communication with the target (NI 9068) and the RT app appeared to hang, without any error or indication of high processor use on the front panel (though this is my suspicion).
This unresponsive state then repeated every time I tried to run my toplevel RT vi, and the issue ceased as soon as I removed the Butterworth Coefficients for loop from the application.
The FPGA code appears to happily compile and run.
 I tinkered with details but am unsure how to proceed to design this better. So I turn to ye magicians. Is this a more complicated task than I think it is?
Attached is stripped down code that represents the RT and FPGA setup.
(2,927 Views)
OK, I should have compiled and run my stripped down code before posting. I discovered that I hadn't set up my 'forum' RT vi properly, and furthermore, it appears to be working fine, although it takes 5ms to run just this little bit of a much larger application.
If I switch to a while loop and run it at full tilt, dt is still the same (5-7ms) but MAX reports processor use at 13 and 15% for cores 1 and 2. Why wouldn't this peg at least one of the cores to 100%? (EDIT: Using the distributed system mgr I see 22 and 88%, makes more sense).
Still looking for a way to reduce dt for this operation. It seems like a relatively simple calculation to generate the configurations, but I don't pretend to know what happens behind the scenes.
Here's the fixed up RT vi.
(2,911 Views)
