Setup custom unit
Hi ALL,
I working on reading flow from my meter. It all has been wired up.
I base on Labview example. As I want to measure the flow through my meter and not the position of the gear wheels inside it, I try using the 'CI Linear Encoder' instance of 'DAQmx Create Virtual Channel' instead of the 'CI Angular Encoder' one.
I then wired the 'volume per pulse' value (2ml in my case)  to this VI as 'distance per pulse'. My problem is now to setup corrent unit (ml) via the 'custom scale name' connector.
Is anyone could help me out.
gregorian7
(2,717 Views)
Two days ago, I posted a response to a question about setting DAQmx up for Scales, and attached a Snippet of my routine here.  It may have the answers you are seeking.
(2,686 Views)
