Settings for serial communications
I am using one of the examples included in LabView 6 for serial communications. I can't get it to work but I believe the problem is the stop bits. How do I can the number of stop bits and baud rate?
(2,973 Views)
You can use the VISA configure serial port vi in order to do what you're looking for. This vi is in the function palette -> Instrument I/O -> Serial.
Hope this helps !
Julien
(2,973 Views)
How do I connect the Visa "Configure Serial Port" into the example. We are using LabView version 6.0
(2,973 Views)
The VI attached comes from NI examples in LV6.1. Write "serial" for the search and select "Serial Communication.vi", this is the one.
Hope this helps !
Julien
(2,973 Views)
We can't open since we have LabView 6.0 Are there any examples in 6.0?
(2,973 Views)
Here's an image of the VI I've attached earlier.
Hope this helps !
Julien
(2,973 Views)
