annulla
Visualizzazione dei risultati per
Cerca invece
Intendevi dire:
Setting up a tpc-2006 with a cfp-2020
Hi all,  hope all is going well, been a while since I was here.  🙂
With a new project we are working on, we have opted for the cfp-2020 unit and the tpc-2006 screen, but we are having a little trouble getting things connected.  I have a feeling that firmware needs upgrading on the 2020 (as the last project's 2020 needed) but it may be more than that.
Any suggestions how to see the project on the 'small screen'?
Cheers for any help you may have 🙂
Steven
Messaggio 1 di 2
2.550Visualizzazioni
Hi Steven
Can I ask you for some more info about what your doing, and what the issue is - what have you done so far in your attempt to get this working? What code have you written? What do these applications do?
If you can give me some more information about where you've got to so far, then I'll see if we can work out where the problem is.
Regards
Hannah
NIUK & Ireland
Messaggio 2 di 2
2.538Visualizzazioni
