Setting up Labview program for higher Analog Read Sampling Rate
   I am trying to use USB-6003 to setup analog Read function to read samples at 10kS/sec. I was able to properly setup the analog read till a sample rate of 100Samples/sec. But, not able to properly set it up for sample rates higher than 100Samples/sec.
It would be really great if I could get some help with this.
Thank you!
(977 Views)
You've to use Read N Samples and not 1 sample to achieve the full sampling rate. Use the DAQmx examples as a starting point.
Santhosh
Soliton Technologies
(963 Views)
