Setting the digits of precision for TDMS logging
I can't seem to figure out a way to set the digits of precision when logging data to a TDMS file. I'm hopping to be able to reduce the file size by doing this. Any suggestions? Thanks, Cosimo
(2,954 Views)
Accepted by topic author cos29
The data in a TDMS file is binary.  So you can't set the digits of precision.  If you want to make smaller files, then cast your data to Singles instead of Doubles.  You will have 1/2 the resolution, but use 1/2 the bits on disk.
(2,946 Views)
Perfect.  Thank you for the quick response.
(2,935 Views)
