Setting realtime date and time on chart display
I cannot seem to get the date and time scale on my graphs to match with the trace.
I am sampling once a second for up to a week.
I am feeding the following parameter to my graph
xscale.format of 7
xscale.maximum  of Current date and time as a double
xscale.multiplier of 1
I have a loop with
wait until next multiple of 1000
My trace appears to be mid window
What I am doing wrong?
Daniel
(2,977 Views)
You might need to specify the xscale range start and minimum. Can you post your code??
(2,971 Views)
(2,941 Views)
Hi Daniel,
I have saved and run your code but I am not having the problem that you describe in your earlier post.
The data I aquire fills the whole of the chart display.
Could you possibly post a screen shot of the trace you are getting?
Also what Operating System are you running on?
If you are using windows I would suggest that you replace the DAQmx Base VIs to DAQmx and switch your device so that you can configure it in MAX.
Regards
Emma Rogulska
NIUK & Ireland
(2,911 Views)
