Setting range limits in a variable until temp. is reach.
This is a furnace that goes up to 1500 C,
I am looking for a function that will allow me to do the following:
I have 4 variables each with their own range of limits for normal operation.
Variable 0: Room temperature to set point, the furnace is WARM UP ( variable two and three are off)
Variable 1: If all temperatures they are with in + - 5 degrees, the furnace is READY to run parts.
Variable 2: If any of the temperatures are more than + - 10 degrees, an Alert message will pop up on the screen.
Variable 3: If any of the temperatures are more than + - 20 degrees, an Alarm message will pop up on the screen and turn off the heat. COOL DOWN
PROBLEM:
I need to look for the variable two and three only when the variable one is reach.
(3,534 Views)
LARG,
You could put variables 2 and 3 in a case that is driven by Variable 1. When Variable 1 is not met, you can through an empty (False)case but when the condition for variable 1 is met, you can check variables 2 and 3 in the True case.
Hope this helps,
AJL
(3,523 Views)
thanks you, i will try tonight.
(3,518 Views)
The problem is the variable one is less than variable two and three, so I will never get any alerts or alarm.
the furnace take 45 min. to reach setpoint
(3,507 Views)
Sorry I didn't full understand the requirements. For a second attampt at solving your problem, you could try a notifier to tell the code variables 2 and 3 are in to start only after the conditoins for variable 1 are met. This will cause the code for variables 2 and 3 not to run until variabel 1 is met then whatever happens to variable 1 the code for variables 2 and 3 will continue to run.
Hope this will help.
AJL
(3,505 Views)
well i did try to used a notifier, but i am new user, and i was not enable to do it. did you have an example that could download from the web.
thanks very much
(3,488 Views)
thanks very much
Hello LARG,
The following links should help demonstrate how to use notifiers.
What Is a Notifier?
Wait for All Notifiers
Notification with 3 Parallel SubVIs
(3,468 Views)
