Setting graph grid parameters
I am usig Labview 2012. I am acquiring an analog volatge that I display on a waveform chart. I would like to be able to choose the space between the vertical time lines of the graph, like for instance have major vertical lines every hour and minor vertical lines every 10 min.
I have checked out the property node of the chart but can't find where to set those parameters.
Does anybody know how to do this?
Thanks.
User
(3,194 Views)
Hi User,
you may try the x axis range property.
But you will be still limited by your chart. Use a graph instead…
(3,192 Views)
Hi GerdW,
Thanks for your answer.
User
(3,156 Views)
