Setting front panel control values using spreadsheet CSV file data
I'm working on a control system algorithm that includes 25 tuning parameters that are adjusted via controls on a Labview front panel. I would like to be able to set these control values according to data stored in a spreadsheet CSV file.
I am almost there, because I can successfully save the parameters to a CSV file, and I can read the parameters back in from the CSV file, but the only way I can find of actually writing the parameters to the front panel controls is to use a separate Invoke Node - Ctrl Val.Set for each parameter, which seems rather long winded.
Are there any other methods of overwriting front panel control values?
(3,223 Views)
Hi John,
Maybe my library will work for you:
http://forums.ni.com/t5/LabVIEW/save-control-values-by-reference-I-have-made-something-that-does/td-...
It saves and restores control data in a text file. Just save it once, and next time just alter the values in the .cfg file with a text editor and load it.
(3,214 Views)
I would personally use an .ini file to configure the controls within the FP. A .ini file is a configuration file. The following example shows this very well. Use the error cluster to ensure data flow, so that the configuration occurs before your code.
http://decibel.ni.com/content/docs/DOC-9259
Regards
Richard S
Certified LabVIEW Associate Developer
National Instruments UK&Ireland
(3,187 Views)
