Setting default values for knob and slider inputs?
I'm using Labview 8.5.1 and have some knob and slider-type inputs on my front panel. How can I set some of them to have specific default values (as opposed to zero) when the VI is run?
Thanks for the help 🙂
(5,941 Views)
Accepted by topic author thomas_p
Set the default value for the slide-type input (or the knob).
Right click on the control.
Select "Data Operations" > "Make Current Value Default"
(5,938 Views)
Cheers for that, worked perfectly 🙂
(5,928 Views)
