Setting a string value from a Sub-VI
I am new at labview and wanted to find an example of changing a string value on the top level by using a Sub-VI to make the change.
Message 1 of 8
(3,956 Views)
Pass a reference to the string control to the subVI.  Then use a property node with the reference to write back to the control.
aputman
Message 2 of 8
(3,951 Views)
Actually that is one way.  There are multiple ways to accomplish it.  Another is to generate your string data and pass it back thru the connector pane.
aputman
Message 3 of 8
(3,947 Views)
not sure how to use a connector pane but if there many strings, not sure if this works easily?
Message 4 of 8
(3,945 Views)
Sub VI
Top level VI
I dont recommend references for beginners because they break the data flow paradigm.
=== Engineer Ambiguously ===
Message 5 of 8
(3,943 Views)
If you don't know how to use connector panes, then I suggest learning the basics.  Watch some videos.  Get acquainted with LabView before building an app.  It will make your life easier in the long run.
http://www.ni.com/gettingstarted/labviewbasics/
aputman
Message 6 of 8
(3,939 Views)
Don't be afraid of arrays and clusters to make passing data around easier.  But passing the value out of the subVI is definately the easiest way to go.
Message 7 of 8
(3,924 Views)
ok, since i am new, is it possible to get an example on passing the data and reference from a sub-vi?
Message 8 of 8
(3,912 Views)
