Setting a loop to run for a set time
Thanks for the quick replys. 🙂 . I put numbers from 10 to 1000 in the numeric control, still no luck. I will change the X-axis increment now.
Message 11 of 41
(1,493 Views)
Open up the Keithly VI's while the code is running.  Put some probes on the wires in there to see what values that code is returning.  I don't have those VI's, so I can't look into them myself to see if there is anything there that could explain it.
Message 12 of 41
(1,491 Views)
I couldnt find the labview driver. Thats why i used the other kind. The readings use to be fine. only after I changed the loop type did does it not work any more.
Ill see if I can figure out the auto error check.
Message 13 of 41
(1,491 Views)
Here is the library of drivers
Message 14 of 41
(1,489 Views)
I probed the wires and the readings are 0 at every reading point.
Message 15 of 41
(1,476 Views)
Put a probe on the output of the Keithley Read vi.  Or you can turn on execution highlighting.  Either of these will allow you to see what value is being returned by the Read vi.  If all values are 0, then you have a problem with the Keithley vi's.
I posted this just as you were posting your last one.  If all the readings are 0, then you have a problem with the Keithley vi's.  Open the read vi and look for errors.  Probe the error out wires.
Message Edited by tbob on 08-22-2007 01:57 PM
- tbob
Inventor of the WORM Global
Message 16 of 41
(1,476 Views)
I don't want the IVI driver. I can download it myself if I ever wanted it. Don't knwo why you couldn't find the LabVIEW drivers. They show up for me when I do a search.
Message Edited by Dennis Knutson on 08-22-2007 02:59 PM
Message 17 of 41
(1,474 Views)
I didn't know I could edit posts on this forum. Would have made my posts much cleaner. 😛
ke2000 Configure Measurement.vi<ERR>
Driver Status:  (Hex 0xBFFF003E) Could not perform operation because of I/O error.
Thats the error Im getting at the "read" drivers.
I'll try replacing the IVI drivers with LabView ones,
Once again. Thanks for everyones help.
Message 18 of 41
(1,463 Views)
Well I just quit and restarted the program and now the readings work again. The time also works. The only thing that doesn't really work is that everytime the program takes a reading the Keithley  says "overflow" on its screen. Any ideas on why its doing this?
Message 19 of 41
(1,449 Views)
nvm I fixed it. Thanks everyone, very very much.
Message 20 of 41
(1,446 Views)
