Setting Sampling Frequency cRIO 9025 with NI 9225 Module
I am using cRIO 9025 w/ NI 9225 Module using Scan engine.  I am puzzled about setting sampling rate in the NI 9225.  Is that the same as the Scan Engine Properties "scan rate" accessible in the Project Explorer window?
I found reference to the "Setting sampling rate is done by a property node "AI Sampling Rate,"  in the forum entry -- http://forums.ni.com/t5/Multifunction-DAQ/Sampling-rate-of-NI-9225/td-p/1765564.
I followed the instructions in the referenced example -- but I cannot find any reference to the "AI Sampling Rate" Property node.
(2,645 Views)
Please review the help fuile for the scan engine:
http://zone.ni.com/reference/en-XX/help/371361H-01/lvioscanhelp/scan_engine/
This as well as links within it should give you all the information you need in order to configure the scan rate.
Jacob K
(2,621 Views)
