Setting Range for a Digital Numeric Control
to control the numeric range of my Numeric Controls i wants to read the
limits from an ini-file. To this point no problem. But how can i set the
minimum and maximum values to the control? I created an attribute node,
but there is no range property avaible?
Is there a way to do that?
regards
Henrik
(4,139 Views)
If using LV6, the attribute node has properties for min, max, incr, and
range mode. Previous versions didn't; so can do the feedback and
filtering on the diagram, but not by setting properties/attributes.
Greg McKaskle
(4,139 Views)
Thanx, in the next weeks i will start with 6i and so i will wait.
Henrik
> Greg McKaskle
(4,139 Views)
There is a property available in LabVIEW 6i
Michael Aivaliotis
Sent via Deja.com http://www.deja.com/
Before you buy.
(4,139 Views)
