Setting Control Values in a cluster
I am aware of the technique to set a control value on another VI's FP using an invoke node and Flatten To String Function, but is there any way to set a value of a control inside a cluster?
Many thanks to anyone who may be able to help.
(3,415 Views)
Hi Dan,
a cluster has a property called Controls[], this returns an array of references of all the cluster elements. You can use each reference to set the element value with the property Value.
I attach a simple vi that shows it.
Good luck,
Alberto Locatelli
(3,415 Views)
Thanks Alberto, thats great. Looking back I probably didn't make myself very clear, but how do you do what you have done in your example but to update a cluster in another currently running VI? I presume you need to use control references/refnums but don't really have a good understanding of these yet.
Any suggestions? thanks for your help,
Dan
(3,415 Views)
Hi Dan,
Definitely! You have to pass to the sub-vi the cluster reference.
See the attached example,
Alberto
(3,415 Views)
