Set x-y scales in intensity plot to match data values
I'm working with an intensity plot, and I'm looking for a quick way to set the x and y scales on an intensity graph to match my experimental x-y data points rather than the array index numbers.   To be more specific, I'm sweeping two gate voltages (V1 and V2) and measuring a resistance R at each point in the 2D V1/V2 plane.  Say I sweep both voltages from 0 to 1V in 0.1V increments, is there an easy way to change the mapping on the x-y scales so that they show 0-1V rather than 0-10 (i.e. the array index)?  In terms of making the measurement in real time I would rather be able to look at the graph and immediately see what voltages I'm applying to my test device without having to take the time to figure out my starting voltage, my step size, and the array index to figure out what voltage my power supply is outputting.  I am sure someone has done this before, but I haven't found it anywhere on the forums.  Thanks!
(3,458 Views)
Accepted by topic author drummerguy
Hi guy,
did you try to set the axis scaling (multiplier/offset)?
(3,454 Views)
HI GerdW,
Thanks for the help.  In case anyone else reads this thread in the future, here is a sample vi with some junk data in it that allows you to play with the offset and multilpier programmatically (note the bottom half of the plot had a zero reading, so that is why it is dark).
(3,440 Views)
