Set start path for vi library manager
Hi
One thing that annoys me if I'm using LV, is the start-path of the vi library manager.
When I'm working on a vi, I'd like the vi library manager tha start with the directory path of this vi (or llb). But everytime I start it, I find myself in the LV-directory. This was ok if I just start LV and then open the library manager, but it's so annoying if I'm working on a project and want to change a llb. 😠
Is there any setting to change this or is this just in LV 7.0?
Thomas
Using LV8.0
Don't be afraid to rate a good answer... 😉
(3,131 Views)
Hi bethko,
I think that you can set the search path in the Tools -> Options -> Paths menu.
Hope this help.
(3,132 Views)
Also, apologies for spelling your name incorrectly.
(3,126 Views)
No problem about the nick-spelling ;).
It does not work if I have to set a static path. I want the library manager to open in the current directory if I'm working on a vi.
For example if I work on a vi which is located in C:\Project\LV\2005\Teststand1\testvi.vi, I want the library manager to open the path C:\Project\LV\2005\Teststand1. If I work on an other vi, I want the library manager to open the path of this other vi.
Using LV8.0
(3,124 Views)
