Set element datatype for obtain queue function to waveform datatype
Hi
I am trying to redo an example code that involves the obtain queue function.
How do I form a cluster of waveform elements so that the "element datatype" becomes waveform, as seen in the figure above?
I need to wire obtain queue function to enqueue function, which has an element as a waveform, as seen below. Appreciate any leads.
Thank you!
(1,769 Views)
You first picture shoes an array of waveforms as type.
Get a waveform constant from the waveform palette and drop it into an empty array container.
For the second part, just wire the constant.
(1,763 Views)
You need to place a waveform constant, "wc" shortcut in quick drop.
~ Helping pave the path to long-term living and thriving in space. ~
(1,737 Views)
Thank you!
(1,732 Views)
