Set column width of a multicolumn listbox in LV touch panel module
I am trying to build an application using LV Touch panel module 8.6 and I am having a problem with multicolumn listboxes. I am setting the the width of the columns by clicking and dragging the separator between the headers, but when I transfer and run my application to a winCE controller the width of the columns is the same for all columns (and very narrow actually).
Does anyone know something about it?
I also noticed the following two problems. When I transfer my application in the winCE controller, the line and column separators are disappeared and the column headers are also disappeared, although I have set them to be visible in my vi.
Thanks in advance.
(3,000 Views)
The issues that you are having are because the LV touch
panel Module does not support "Moveable column separators" and
"Row and column headers". The limitations of using a touch panel are available
in the LabVIEW help file.
A possible workaround may be to use a series of arrays with a string data
type then using a single scrollbar control multiple property nodes.
I have attached an example.
I hope this has helped.
Philip
Philip
UK Branch
===If this fixes your problem, mark as solution!===
(2,975 Views)
Philip
UK Branch
(2,973 Views)
