Set / Reset Function
2 years ago I posted this question and thought it time for an update.  In a recent project I created a set / reset (latch / unlatch) function in logic that worked but could be more efficient as a Labview funtion.  Since several revisions of Labview have been released with more features, does anyone know if such a function has been added?
Thanks in advance,
Doug Dunlap
(3,437 Views)
Links to the other threads he is referring to.
http://forums.ni.com/ni/board/message?board.id=170&message.id=166967#M166967
http://forums.ni.com/ni/board/message?board.id=170&message.id=166971#M166971
I have not seen any function like this in recent LabVIEW versions.  But it would not be so difficult to create using an action engine that I don't think it would be necessary for LabVIEW to create one.  In addition, there could be so many different ways you might want to latch or unlatch that a programming solution for one person might not be good for someone else.
(3,434 Views)
You could implement something called an Action Engine to do so.
Or also look for a Functional Global Variable which could do the trick.
RayR
(3,433 Views)
