Set Date/Time
how can i set an arbitrary Time an Date to x-axis?
Message 1 of 8
(4,162 Views)
Hiii, Donald
      Just look at the question "Time Stamp read problem with Spreadsheet String To Array [ 1 2 3 4 ] ", which is in the first page here, you will get lot of answers for sure, and this post is exactly below this, just look it
Nishant
Message 2 of 8
(4,156 Views)
thank you for your answer 🙂
I try to find a solution for my problem.
Message 3 of 8
(4,141 Views)
Hello
Nishant can you give my an example how to set the X-Scale of a graph on 00:00:00 time and 17.01.05 date?
Thanks.
Message 4 of 8
(4,134 Views)
Hiii, Donald,
 Here is your example and from this you will get the idea about how to set the time and date in the graph, and here whrer i have given the time by numeric, if you give Date/Time from the time palette, you will get the current time.
Nishant
Message Edited by Nishant on 02-06-2006 10:41 PM
Message 5 of 8
(4,101 Views)
Tank you once more.
Your solution was my latest idea 🙂 but it doesn't work.
Now I've found the fault 🙂
Message 6 of 8
(4,094 Views)
Hiii, Donald
    Glad to help you, and i ll help again if it is possible for me.Smiley Happy
Please rate the answer, if you fill satisfaction.Smiley Wink
Nishant
Message 7 of 8
(4,090 Views)
Here is the answer
Message 8 of 8
(4,049 Views)
