Servo Duty Cycle
Hello!
I am trying to create a PWM duty cycle for a servo motor using only LabVIEW and a Pololu Micro Maestro board. Does anyone know if this is possible or would I need additional hardware like myRIO or myDAQ?
Thanks so much!
(2,267 Views)
Yes you will be able to control the board through USB. You don't need any additional hardware.
From the product page :  "Virtual COM port makes it easy to send serial commands from any development environment that supports serial communication"
Look at the resources, they say it is easy : "there is a class library that allows your program to interact with the device using simple, high-level function calls"
I didn't know Pololu, I will definitely check their other boards.
Yddet
(2,219 Views)
