Servo Controller SD21
I want to control 20 Servos with Labview, to do this i have
a SD21 Servo Controller
http://www.roboter-teile.de/Oxid/Motor-S...param=sd21
with a PICAXE 18X Driver IC
http://www.picaxe.com/docs/picaxe_manual1.pdf
and this is connected with an USB Adapter
http://www.roboter-teile.de/Oxid/Sonstig...modul.html
I know that this Hardware is working with Labview because i already have
seen it working 😉 but i dont know how to connect it correctly (VISA or is it something differnt?)
I would be really happy and thankful for help 🙂
Greetings
Steffen
(2,728 Views)
Hi zerberus,
maybe this documentation can help you. Basicly, it's the same thing for any Hardware, not only plug-in-boards:
http://digital.ni.com/public.nsf/allkb/F3009806E2AE416E8525645D0076B962?OpenDocument
I don't think it will be as easy as it seems, because you'll need to adress a unsupported control-module through an unsupported USB-adapter. If you have a slightly bigger budget, you should consider using an 8541 i2c-interface.
Oliver
(2,692 Views)
