Server & Client in Mac
I have designed a server & client programs in LabVIEW to interact with each other. The problem is that it works fine in windows but it doesn't allow the connection using 2 MacBooks.
So, does anyone know how to lower the privacy in mac to allow a connection between 2 programs (server/client)??
(3,533 Views)
Hello AA10,
Here is a link that could help you:
https://www.lifewire.com/use-mac-security-preference-pane-2260745
Regards.
(3,504 Views)
I tried disabling the firewall but it is still not working..
(3,475 Views)
Are you getting an error window from LabVIEW? If you are, please send the screenshot with the error.
Regards.
(3,472 Views)
No, I am not getting any error from LabVIEW.
The server is running in LabVIEW and the client is running in Android Studio, they work fine when I run them in the same laptop (mac) but when I try to run for example the LabVIEW or the android on another device they don't connect to each other. The server keeps running without any connectivity to the client.
I have tried turning the frame wall off but it still not working..
So I am not sure how can I connect a mac device to another device by TCP connection?? is there anything else that I can do to lower the security/privacy in my device to allow other devices to connect to it?
(3,469 Views)
