Serial
Hi Centerbolt and everybody in the forum.
Well, at least the interface is running, and it works perfectly. All the hardware as I supposed was fine, the program in a big sense is right too, but there´s a little tiny mistake that provoke that the entire system doesn´t works as I expected. The problem was that I didn´t wire the TERMINATION CHARACTER ENABLE so, because the default state is TRUE, when the system recognizes this character ends the reception, so the solution was WIRE A BOOLEAN CONTROL AND TURN IT TO FALSE. When I did this all begins to works.
I can´t identify the problem before because the analog inputs of the system in much cases were connected to voltages greater than 0 V. So the default termination character is a 0xA, when the voltage goes down enough, the reception is terminated because the detection of this character in the stream of RS232 data.
So, my advice is: CHECK ALL THE UNWIRED CONNECTIONS and CHECK THE DEFAULT VALUES of the blocks that you´re using in your VIs.
Thanks to all for the tips and suggestions, specially Centerbolt for dedicate so much time to my problem.
Message 11 of 12
(771 Views)
Hi AleskF, I've read in detail your project to acquire analog signals and to control servomotors with LabView and a PIC16F877. I am actually doing the same project but I have had troubles and I don´t know if it is the electronic circuits or the software. I started trying with matlab, but when a plot the data from the analog signals there are points where the values are not consistent with the expected ones, I thought it was my routine in the PIC, and I try to made te conversion with an ADC 0809 converter, but i still have the problem.
On other hand, I am getting the same problem that you had; sometimes the data acquisition is stoped when I'm acquiring and controlling servos. On this way after reading your messages on the forum, I decide to try with LabView but the problem is the same. Right now I am using the USB 6008 data acquisition card from NI to check how is the signal, but it´s ok, the only problem is that it seems to be slower the response to the servo routine using rs232.
I am new in this stuff so I will realy aprecciate if you could help me with the electronic based on the PIC just in the A/D conversion because the servo routine works fine for me, and beacuse the USB 6008 card is from the University lab, and I want to develop my own data acquisition system.
Thanks a lot.
Message 12 of 12
(638 Views)
