Serial read not giving an output?
Omar II. That program still hangs up at the read function and has the timeout error
Message 21 of 41
(1,584 Views)
But did you get anything back?
I go back to my first question.
Have you gotten it to work with some type of terminal program like hyperterminal or TeraTerm?
Are you sure your cable is correct? Do you need a null modem?
Omar
Message 22 of 41
(1,577 Views)
i ddi not get anything back no, just the same error. as far as i can tell from reading the manual it should be a straight plug n read serial device like i have used in the past with other labview programs. I dont know why this is causing such difficulty.  When i try to run the hyperterminal on my computer i get this error:  windows has reported a TAPI error.
Message 23 of 41
(1,575 Views)
Got the hypterminal to connect! but the commands arent working, i send TS and get nothing back
Message 24 of 41
(1,558 Views)
@Omar II wrote:
\n= new line
\r = Carriage Return
"Should be" isn't "Is" -Jay
Message 25 of 41
(1,557 Views)
As far as i can tell I have done everything listed to fix this problem here:
http://digital.ni.com/public.nsf/allkb/E6DFA2B8D7E99F9886256C14005E82F7
it is still crashing though.
Message 26 of 41
(1,543 Views)
maybe I missed a previous mention of it, I just breezed through the posts, but you sure you're got the right cable? straight thru or crossover?
-pat
Message 27 of 41
(1,533 Views)
I think you problem is outside of LabVIEW or Hyper Terminal. If Hyper Terminal does not work I do not think LabVIEW will work.
Check the comm port in Device Manager.
Check the comm port in MAX.
Open a VISA Test Panel in MAX see if that works.
Find something else to try to talk to, to make sure your cable and comm port are working.
Omar
Message 28 of 41
(1,530 Views)
How do i tell that? I am using a serial cable connected directly to the serial port on the computer.
Message 29 of 41
(1,528 Views)
maybe i can try and find a serial device by tomorrow. i  was surprised that the detector used it instead of usb to be honest. but i sent the company an email asking for help as well. hopefully they get back to me and i can get back to all of you.
Message 30 of 41
(1,524 Views)
