Serial read multiple sensors (Encoder+Accelerometer)
Im working on this project where require interface encoder and accelerometer at one-time. I tried to read the serial data and use it to plot a graph( real-time).
Problem;
1. Everytime i run it will always pop-out error
2. There are delay in signal in labview when i try to read through real-time graph.
Thank you,
Effendywoo
Message 1 of 15
(6,386 Views)
Your pictures are tiny.  I can barely make out what the error code was.
Your format string for hte Scan From String is not matching the data coming in.  Do you have an example of the data string going into the Scan From String?
Message 2 of 15
(6,349 Views)
Here is my example data,
Note: "the value zero is for the encoders value (2 dc).
The error pop-out,
Effendywoo
Message 3 of 15
(6,332 Views)
What is the character seperating those numbers?  Tab?  Space?  Some other non-visible character?
Message 4 of 15
(6,321 Views)
Only space that seprate the data,
Example;
Row1     Row 2      Row3   Row4     Row5
Time   Encoder1   Enc2    X-axis    Y-axis
0.5           100.2      120.8       67           87
1.2           200.4      300.4       20           21
Effendywoo
Message 5 of 15
(6,300 Views)
I suspect (arg 1) is empty!
What is in your "substring"
You have to write code to make sure what you read back from the VISA read is valid before passing it to the "Scan From String"
Did the VISA Read throw an error?
What is the termination char setting for your VISA read?
Omar
Message 6 of 15
(6,298 Views)
Hi Omar,
Visa read does not throw any error. here is the data i get when i try to probe after "String subset".
Effendywoo
Message 7 of 15
(6,295 Views)
Then your format string needs to have the spaces.  So your format string should really be "%f %f %f %f %f".
Message 8 of 15
(6,291 Views)
@fendy90 wrote:
Hi Omar,
When dealing with instrument communications, it helps a lot if you change the display style of those indicators to be "\ Codes".  Then it becomes obvious what is seperating your data.
Message 9 of 15
(6,288 Views)
What do you mean by changing the data to "codes"? I try to format as "%f %f %f %f %f" and it seems not working out.
Effendywoo
Message 10 of 15
(6,265 Views)
