Serial port - interrupt
Good afternoon,
I have a question, on a project that I'm doing ..
How can i stop sending the serial port without disconnecting the serial port?
thanks
Message 1 of 13
(3,339 Views)
What exactly do you mean by "stop sending the serial port"?
If you are continually writing data to the serial port to send out data, then you just stop writing data to it.
Message 2 of 13
(3,317 Views)
I want to send 4 bits, and stop.
and only when you ask to send again, the serial port send and stop ..
Message 3 of 13
(3,314 Views)
... and labview must remain active.
Message 4 of 13
(3,312 Views)
Your question makes little sense. Can you show us a simplified version of your code?
Message 5 of 13
(3,297 Views)
I send 2 cases, true or false..
Message 6 of 13
(3,284 Views)
If you want i send a program (.vi)..
Message 7 of 13
(3,283 Views)
Yes.  Attach the VI.  Partial screenshots show us nothing.  We can't even tell if and where a loop is in your program.
Note.  Serial ports don't send bits.  They send bytes.
So did you mean to say that you program sends 4 bytes?
Message 8 of 13
(3,271 Views)
thank you for the answer.
I wanted to say bytes ...
Message 9 of 13
(3,262 Views)
Message 10 of 13
(3,261 Views)
