Serial port, flushes after write
Hello All
After I send a byte to serial port via VISA, the flush operation is performed. I have traced the commands and I have found out that it is done inside "VISA write" which of course I can not edit.
I imagine, that there is some option I need to set to avoid flushing every time I send simething, but could you tell me where?
thanks in advance
Pawel
(3,017 Views)
I'm not sure that I've got your problem correctly but in the palette
"Functions->Instrument I/O->VISA->VISA Advanced->Interface Specific"
you can find 2 functions:
"VISA Set I/O Buffer Size" and
"VISA Flush I/O Buffer"
which can set and flush both input and output buffers of your instrument.
Good luck.
Oleg Chutko.
(3,017 Views)
Thank you Oleg
Pawel
(3,017 Views)
Thanks also from me. This is exactly the information I needed.
(3,017 Views)
