Serial communication with generator and NI USB 6008
I would do serial communication between NI USB 6008 and power generator; Its name is EA-PS 3150-04 B. This is my programm. Can you help me please?
Message 1 of 15
(4,172 Views)
Hi ki4,
NI6008 doesn't support any serial communication, it's just a cheap DAQ device.
What kind of help do you need?
Message 2 of 15
(4,158 Views)
So to give a brief catch up for newcomers, this is a continuation of a thread here: https://forums.ni.com/t5/Multifunction-DAQ/Serial-communication/m-p/3924391
Hopefully we're already agreed that some different hardware (i.e. USB to Serial converter) will be sourced/purchased/found and used.
That being said, there's now a part number for a specific device. The previous thread discussed trying to read "the values" of a "generator", so I'm guessing that'd be the voltage or current levels.
The datasheet for the mentioned part can be found at https://www.electronicsdatasheets.com/manufacturers/ea-elektroautomatik-gmbh--co-kg/parts/eaps-31500... although briefly scanning that makes it seem like a lot of the previous question might need revisiting.
There isn't a manual listed at https://www.enrgtech.co.uk/buy/product/ET13959870/PS-3150-04B but a similar part (https://www.enrgtech.co.uk/buy/product/ET14014675/PS-3032-10B) contains a multi-lingual manual describing an analog interface.
There's no description of a serial interface in any of these documents that I can see.
Can you first confirm that's the part you're interested in?
If so, where did you get information leading you to use Serial/VISA code to interact with the device?
What do you want to do with this? What do you want to read/write?
GCentral
Message 3 of 15
(4,155 Views)
Yes, this is the part I'm intersted in. I will check some details and I tell you more informations. Thank you!
Message 4 of 15
(4,147 Views)
The Elektro-Automatik devices have normally 0-10V programmable analog inputs for current and voltage control. You can either control these with the mentioned USB module or get from Elektro-Automatik a special EA-UTA12 USB interface that allows to do the same. According to the Elektro-Automatik datasheet for this device, they support LabVIEW and Visual Basic access for this interface.
Rolf Kalbermatter  My Blog
Message 5 of 15
(4,140 Views)
What I would do exaclty is to send the file where I put the results of counter to an other computer by doing serial communication.
Message 6 of 15
(4,129 Views)
Hi ki4,
And what is the problem?
(Why do you want to send a "file" instead of the current counter value?)
Message 7 of 15
(4,127 Views)
Ya the current value of the counter in an other computer by using the serial communication. NOT FILE SORRY
Message 8 of 15
(4,125 Views)
So, How to do it. Now, I find the port in Visa port detection. But when I run the programm, nothing happen!
Message 9 of 15
(4,115 Views)
Hi ki4,
What should happen?
Do you get any errors after the VISAWrite function?
Which device is receiving the data you send to that COM port? Which tool is used to receive that data?
Did you check the cable used for the serial communication?
Does the receiver understand the data format you are using for sending?
Message 10 of 15
(4,110 Views)
